Adobe Plugin Issues Fix and cool Improvement
Issues Fix
what is the problem with the plugin for Adobе:
Real case: I open several files with the same set of fonts. Then I close one of the files and the fonts are disabled in the rest, since one of the files is closed and the plugin disables fonts.
I suggest disabling fonts not by the file close event, but by the closing of the entire application.
Cool Improvement
1.
Setting that allow Adobe plugin to activate not only one typer-face but whole font-family.
Sample: I open one Adobe Illustrator file that include OpenSans Reg. Plug in switch-on not only Regular but all OpenSans family and I can use all styles.
2.
Right click on the font-family allows you to collect selected fonts to the folder you choose.
Suitcase works this way
I hope you like it
double check the settings
