Battery drain of Fontbase background process
Hi at Fontbase
I start it here as a new question again - posted yesterday as an answer in “Higher CPU usage than normal”.
I use an almost new power-notebook (14") with Windows 11 26H2 and started testing battery time …
Now (FB 2026.7.0) I encounter still high/permanent wavering CPU load (on workstation with new I7 not so much as with the notebook) and also at the new power-notebook (AMD) high battery consumption (I’ll check again for the next loading cycles). OK, I’ve many fonts (also Google fonts offline) and some folders contain many subfolders … but this also shouldn’t cause high load. In idle mode - doing definitely nothing - Fontbase shoud do nothing (except first content scan).
Regards, Matt
PS: I like Fontbase but the battery drain is a real problem with my notebook.
Hello Matt, thank you for your post :folded_hands:
I’m afraid that with the higher number of fonts and folders (especially with many subfolders) FontBase will consume more system resources than having let’s say 1k fonts in several folders.
I do understand your sentiment that FontBase should do nothing after the first content scan, but unfortunately that would mean no tracking of any changes to folders/fonts added into the app, i.e. no sync.
Hello yuriy
Thank you for your answer. I understand this behavior of Fontbase but I’m wondering if this could be possible with less battery consumption. The CPU load is not that important (powerful processors) but battery time with notebook is an issue … As I wrote, I will check the consumption for the next loading cycles …
Regards, Matt
Hi Yuriy, thanks for explaining. I’ve also experienced persistent idle CPU usage with a large font library, so this topic is relevant to me.
I understand that initial indexing and processing changes will require more resources with larger collections. Would you consider event-driven folder monitoring to reduce the work needed when nothing has changed?
On Windows, ReadDirectoryChangesW supports change notifications for a directory tree, and Node’s fs.watch uses that mechanism. An initial scan followed by targeted updates could potentially keep the library synchronized with much lower idle CPU usage.
I appreciate that notification overflows, junctions, disconnected drives, and network folders require careful handling. Occasional reconciliation scans or fallback polling might still be necessary.
Is this an approach the team would consider, or are there constraints in FontBase’s architecture that make it difficult? Keeping a large collection available and synchronized while minimizing background CPU use would be a valuable improvement, particularly for laptop battery life.
Thanks for considering it.
Hello Josh, thank you for your post :folded_hands:
These are excellent suggestions, in the past the team had considered all the options you’ve mentioned, as well as some others iirc. In the end the most stable and reliable option was implemented from what I know. After all, having a more light-weight solution that fails to keep the font library in sync would be quite detrimental to many users.
Hi yuriy
Short question: what do you think about number of folders? Some of my font folders contain folders for every font or font familiy (eg. also my local used copy of google fonts). so there is really a huge number of folders. Could it help much for background activity to eliminate the subfolders? Now Fontbase background process uses around 700MB RAM and CPU usage permanent switching from 0 up to around 5%.
Regards, Matt
Hello Matt, really sorry for such a delay and thank you for your post :folded_hands:
Decreasing the number of subfolders in your case should make a considerable difference, yes.
