Certain fonts show up only when moved out of subfolder
Some fonts in the same subfolder are not showing up in FontBase at all. If I move the said font into the root folder, then it shows up as available.
All fonts are stored locally in C:\Users{username}\FontBase and I have added all folders manually.
In this case I moved LHF Desire out of the LHF folder to root. Now it shows up. None of that family shows up from the subfolder, but other LHF fonts do.
  • Win 10 Pro Version 21H1
  • FontBase version 2.17.5
  • Has been like this for several versions
Hello @dasignlady, welcome to the forum, thank you for your post and sorry for the delay in replying.
Does this keep happening even if the “LHF Fonts” folder (with all the fonts inside of it) is removed from the root folder (and as a result removed from FontBase) and then re-added (just as it was, with fonts inside, not moving them one by one to the root)?
