Error Loading plugins Illustrator 2020
Hi , can get the auto activation plugin to work in Illustrator 2020 on macOS Big Sur Macmini m1 machine, this is crucial to my workflow, im attaching screenshots of both fontbase and finder that shows the plug in. Screen Shot 2021-06-01 at 18.11.08 Screen Shot 2021-06-01 at 18.16.00
Does the fact that is marked as .localized has something to do ?
Are you using the latest available update of 2020 Illustrator?
Hi I’m on build 24.1
Can you try updating to the latest build? I think it’s 24.3.xx.
