Flag fonts to ignore auto close
Hi!
Is there a way to flag or pin a font (or a collection) so that the plugin doesn’t deactivate them? Or maybe only deactivates them when the program closes?
When I have two documents open in Illustrator that use the same fonts and then close one of them it deactivates the fonts altogether even though the other document also using them is still open.
I have to either close and reopen the other page as well or manually reactivate the font in FB.
You can turn off automatic deactivation in settings. That way the fonts will be deactivated only when you close the app. There is no per-font setting for this.
Okay, thanks. I’ll try that.
