FontBase Search Randomly Removing Characters
  • Your operating system
Win 11
  • FontBase version
2.19.4.
  • What actions caused the issue
When using the Fontbase search field, the application decides to randomly remove characters as you type. Many times now I have to go back and re-add a character because Fontbase has decided to remove it. It’s a frustrating bug
Hello @Odin, thank you for your post :pray:
Does this still happen with the latest update?
Thanks you again,
