Fonts get deactivated when I close FontBase
As long as the app is running, everything is fine. Whenever I close the app, all the fonts I have activated get deactivated.
  • Your Windows 10 Home
  • 21H2
  • FontBase version 2.16.9
  • What actions caused the issue: Closing the app.
  • If possible, attach a screenshot: Sorry, no
FontBase is designed this way. To keep the fonts active, FontBase needs to be running.
@ Frol - go to settings / app behavior and activate the first 3 buttons. So the app will allways runs in system tray / background (you don’t see it in task bar) and if you click close button of the app in upper right corner it doesn’t close but “goes” back to system tray.
Thank you very much Matty! You’re the best!
