On 1 Win10 PC, FB only starts on 1st Start after (Re-)Installation
Hi everyone,
on one Win10-PC Fontbase only starts after the Installation or Re-Installation of Fontbase.
Dont know how that can be possible, but this is the fact.
I also tried it, to delete the folder “C:\Users\username\AppData\Roaming\Fontbase” before start, and even before Reinstallation.
I can reproduce the fast first start after reinstallation.
any other ideas, as deleting the fontbase-dir in userdir, cause this doesnt work for me.
many thx. Pit
Hello,
What is the install location of FontBase on your computer?
Hi Dominik,
its c:\Program Files\FontBase
Can you try installing it in your user home folder instead? There’s a second option during install to do this.
Hi dominik,
i installed in C:\Users_username_\AppData\Local\Programs\FontBase
Now it seems to work. I tested, by starting/closing FB several times. I dont know if it will now work forever, but at the moment, the problem seems to be solved.
many thx.
