Postscript fonts not showing
So I’m trying to import all my old adobe fonts (postscript), and it made folders for them, but the colection says 0 and theres nothing in the folders. Is postscript not doable in this app?
Postscript fonts are not supported. We only support OTF and TTF fonts.
Is there any plan to support Postscript fonts with future releases? Otherwise really pleased with the software and would happily subscribe. Unfortunately I do legacy design work and not being able to access half of my fonts is a deal-breaker. Thank you.
Currently there are no plans to add Postscript fonts.
Thanks for your reply. Your software is excellent and wishing you every success with it.
