i seem to have done it before; but now i can see no way to add, or save, additional text sample strings
Hi @dec, thank you for your post ![]()
Have you already tried the “Text samples” section in the Settings page?
hi there Yuri
hmm. yes, i see that
hmmm, it seems issue is that that options list just FIVE lines of sample text strings (which you can replace or alter); but it appears you can not have more than five.
Thank you for the quick reply ![]()
Indeed, the current number of editable sample lines is 5, you are correct.
Noted, Yuriy.
the way it currently works is a bit clunky and buggy; but i would have to think about how it should be made more easy and useable
Thank you for your feedback ![]()
May I ask what do you mean by clunky and buggy?
I don’t think I’ve heard any users describe this feature in this way before. Also, when you mention making it useable, do you mean the feature is unusable now?
i will attempt to document the usability issues i have found later
