Apparently there is no longer any conflict or crashes.
However, the fonts are not auto-activating.
Even though I manually inserted the file into the Plugin folder, the Fontbase app does not recognize it when I open the Settings menu.
Hi Dominik, I just try the plugin āFontBase-Mac-Illustrator-2026.aipā
This is how I did:
- I closed Illustrator and FontBase.
- I copy the file into Aiās plugin folder.
- I opened FontBase and Illustrator in that order.
When Illustrator opens give me an error message: āFontBase-Mac-Illustrator-2026.aipā is damaged and canāt be open.
- Hit āOkā 4 times and then a new message: Plugin issues detected. To fix the issues, you can try relaunching Illustrator in safe mode.FontBase-Mac-Illustrator-2026.aip
- Hit ok and Ai finally launches but the Plugin doesnāt work.
Iām working on a 2020 intel based computer.
