[Feature request] Improved support for variable fonts alongside static fonts
My libraries have plenty of variable fonts, and for most of them, I also have the static versions on the side.
Right now, they are quite correctly seen as “duplicates”. However:
– It’s not clear which ones are variable fonts or not. Sometimes the file name or file format is not enough to guess. It would be great to add a little icon or something next to them to differentiate them.
– When activating a family, it’s not clear how it chooses between activating the statics or the variable. Maybe there should be an option to choose which to activate, ideally each time, or at least as a preference.
Of course it would be amazing to have options to preview/manipulate variable axis, but I know that’s much more to ask for. But little improvements management-wise would be great already!
Thank you for your post @nclm :pray:
Good suggestions, thank you :pray:
Have you already had the chance to check out the Waterfall tab in the Family page? It contains the variable axis manipulation and preview similar to what you’ve mentioned.
Oops I missed that, thanks very useful!
The two main points remain: having a more visible/consistent way to see which are the variable fonts and how they get activated compared to their sidecar static versions :slight_smile:
