FontBase 2.25.10 crashes instantly after start
Issue happens today. This version worked fine till few hours ago. No new software was installed. Uninstalling, cleaning and installing again had no affection.
Have you tried to reset the settings? https://fontba.se/learn/reset-settings
It helps.
Uninstalling the app. Cleaning all apps’ footprints. And installing again.
But now I’ve got the next issue:
Error: New version 2026.2.0 is not signed by the application owner: publisherNames: Dominik Levitsky Studio, LLC, raw info: {
“SignerCertificate”: {
“FriendlyName”: “”,
“IssuerName”: {
“Name”: “CN=Microsoft ID Verified CS EOC CA 01, O=Microsoft Corporation, C=US”,
“Oid”: “System.Security.Cryptography.Oid”
“NotAfter”: “/Date(1771746742000)/”,
“NotBefore”: “/Date(1771487542000)/”,
“PrivateKey”: null,
“PublicKey”: {
“Key”: “System.Security.Cryptography.RSACryptoServiceProvider”,
“Oid”: “System.Security.Cryptography.Oid”,
“EncodedKeyValue”: “System.Security.Cryptography.AsnEncodedData”,
“EncodedParameters”: “System.Security.Cryptography.AsnEncodedData”
“SerialNumber”: “330006FED8A8C482E92E3E9E5800000006FED8”,
“SignatureAlgorithm”: {
“Value”: “1.2.840.113549.1.1.12”,
“FriendlyName”: “sha384RSA”
“Thumbprint”: “C9F65A11370D109322F3A761994B426F286D5B2E”,
“Version”: 3,
“Issuer”: “CN=Microsoft ID Verified CS EOC CA 01, O=Microsoft Corporation, C=US”,
“Subject”: “CN=Senary Domain LLC, O=Senary Domain LLC, L=Dover, S=Delaware, C=US”
“TimeStamperCertificate”: {
“Archived”: false,
“Extensions”: [
“System.Security.Cryptography.X509Certificates.X509SubjectKeyIdentifierExtension”,
“System.Security.Cryptography.X509Certificates.X509Extension”,
“System.Security.Cryptography.X509Certificates.X509BasicConstraintsExtension”,
“System.Security.Cryptography.X509Certificates.X509EnhancedKeyUsageExtension”,
“System.Security.Cryptography.X509Certificates.X509KeyUsageExtension”,
“FriendlyName”: “”,
“IssuerName”: {
“Name”: “CN=Microsoft Public RSA Timestamping CA 2020, O=Microsoft Corporation, C=US”,
“NotAfter”: “/Date(1792702009000)/”,
“NotBefore”: “/Date(1761252409000)/”,
“HasPrivateKey”: false,
“PrivateKey”: null,
“PublicKey”: {
“SerialNumber”: “3300000055D9DD692628F9F8E2000000000055”,
“SubjectName”: {
“Name”: “CN=Microsoft Public RSA Time Stamping Authority, OU=nShield TSS ESN:7D00-05E0-D947, OU=Microsoft America Operations, O=Microsoft Corporation, L=Redmond, S=Washington, C=US”,
“Thumbprint”: “1D3B54018265BFB6E0595791068E17EC57870DEA”,
“Version”: 3,
“Handle”: 2098040973040,
“Issuer”: “CN=Microsoft Public RSA Timestamping CA 2020, O=Microsoft Corporation, C=US”,
“Subject”: “CN=Microsoft Public RSA Time Stamping Authority, OU=nShield TSS ESN:7D00-05E0-D947, OU=Microsoft America Operations, O=Microsoft Corporation, L=Redmond, S=Washington, C=US”
“Status”: 0,
“StatusMessage”: “Signature verified.”,
“Path”: “C:\Users\HP Omen\AppData\Local\fontbase-app-updater\pending\temp-FontBase-2026.2.0.exe”
at t.newError (C:\Program Files\FontBase\resources\app.asar\dist\main.js:2:497944)
at Object.task (C:\Program Files\FontBase\resources\app.asar\dist\main.js:2:73165)
at async d.executeDownload (C:\Program Files\FontBase\resources\app.asar\dist\main.js:2:319260)
To fix this, please download the latest version from our website and install it.
The program keeps crashing. I’ve already reset it three times, and after working for a while it crashes again. Please fix this, it’s getting in the way of my work. Thanks.
Crashes do seem pretty regular at the moment. It’s usable for me, but it seems like about once a day I’ll look in my taskbar and notice the Fontbase icon has disappeared, and it ends up needing to be restarted.
Hello there,
I am having the same “New version 2026.2.5 is not signed by the application owner” error.
I had to reinstall the application about 3 or 4 times before trying to reset the settings, and after apparently getting fixed, the other “not signer by the application owner” problem came in. Weird thing is that it was working fine just yesterday.
Could you send over your log files located at “C:\Users\USERNAME\AppData\Roaming\FontBase\logs\main.log” on Windows and “~/Library/Logs/FontBase/main.log” on Mac?
Same problem as described by other users: “New version 2026.2.5 is not signed by the application owner” on Windows 11. The app keeps crashing a few seconds after launching. Restart and it crashes again and so on. I can’t work, so will need to look for an alternative if not resolved soon. Thank you!!
Have you tried to download and install the latest version 2026.2.5 from our website? FontBase — Downloads
Yes, as you see in my post, the error message refers to the version: 2026.2.5
Thank you so much!
The message “New version 2026.2.5 is not signed by the application owner” can not appear on the version 2026.2.5. Are you sure you have installed the latest version and launching it, not an older version of the app?
You’re quite right!!! I had checked and downloaded the latest version this morning and only saw 2026.2.5 in the name of the downloaded ap, which is the same as my installed app says, so I just presumed I had the latest version. Thank you SO MUCH for the wonderful support! :heart:
The same for me even though I have already downloaded and installed the latest version 2026.2.5
I have reinstalled it thrice.. I does not run. Same message “Something bad happened.”
Here is my logs:
[2026-01-08 20:51:52.052] [info] ------ Main process started ------
[2026-01-08 20:51:52.949] [info] Startup 823
[2026-01-09 18:45:58.236] [info] ------ Main process started ------
[2026-01-09 18:45:59.522] [info] Startup 1195
[2026-01-10 06:20:52.408] [info] ------ Main process started ------
[2026-01-10 06:20:53.424] [info] Startup 959
[2026-01-10 22:01:10.465] [info] ------ Main process started ------
[2026-01-10 22:01:11.505] [info] Startup 980
[2026-01-11 14:06:13.178] [info] ------ Main process started ------
[2026-01-11 14:06:14.331] [info] Startup 1077
[2026-01-13 19:23:04.597] [info] ------ Main process started ------
[2026-01-13 19:23:05.532] [info] Startup 874
[2026-01-13 21:18:00.232] [info] ------ Main process started ------
[2026-01-13 21:18:01.543] [info] Startup 1256
[2026-01-14 09:49:20.823] [info] ------ Main process started ------
[2026-01-14 09:49:21.861] [info] Startup 970
[2026-01-15 05:17:21.043] [info] ------ Main process started ------
[2026-01-15 05:17:22.248] [info] Startup 1143
[2026-01-17 21:12:31.548] [info] ------ Main process started ------
[2026-01-17 21:12:32.910] [info] Startup 1303
[2026-01-19 09:12:56.565] [info] ------ Main process started ------
[2026-01-19 09:12:57.689] [info] Startup 1057
[2026-01-19 10:39:11.286] [info] ------ Main process started ------
[2026-01-19 10:39:12.381] [info] Startup 1035
[2026-01-19 10:52:43.230] [info] ------ Main process started ------
[2026-01-19 10:52:44.286] [info] Startup 992
[2026-01-19 21:23:36.188] [info] ------ Main process started ------
[2026-01-19 21:23:37.366] [info] Startup 1104
[2026-01-20 05:52:27.934] [info] ------ Main process started ------
[2026-01-20 05:52:29.094] [info] Startup 1093
[2026-01-21 15:33:24.065] [info] ------ Main process started ------
[2026-01-21 15:33:25.286] [info] Startup 1159
[2026-01-21 16:53:49.821] [info] ------ Main process started ------
[2026-01-21 16:53:50.909] [info] Startup 1021
[2026-01-21 17:10:04.350] [info] ------ Main process started ------
[2026-01-21 17:10:05.446] [info] Startup 1038
[2026-01-22 13:30:35.695] [info] ------ Main process started ------
[2026-01-22 13:30:36.846] [info] Startup 1088
[2026-01-25 19:35:41.903] [info] ------ Main process started ------
[2026-01-25 19:35:43.287] [info] Startup 1319
[2026-01-25 21:41:07.849] [info] ------ Main process started ------
[2026-01-25 21:41:08.989] [info] Startup 1079
[2026-01-26 03:42:00.919] [info] ------ Main process started ------
[2026-01-26 03:42:02.027] [info] Startup 1036
[2026-01-26 14:47:28.978] [info] ------ Main process started ------
[2026-01-26 14:47:30.119] [info] Startup 1078
[2026-01-27 19:36:50.120] [info] ------ Main process started ------
[2026-01-27 19:36:51.085] [info] Startup 903
[2026-01-27 19:43:08.856] [info] ------ Main process started ------
[2026-01-27 19:43:09.913] [info] Startup 990
[2026-01-28 07:41:18.593] [info] ------ Main process started ------
[2026-01-28 07:41:19.683] [info] Startup 1029
[2026-01-28 21:13:57.318] [info] ------ Main process started ------
[2026-01-28 21:13:58.383] [info] Startup 1006
[2026-01-30 15:11:24.774] [info] ------ Main process started ------
[2026-01-30 15:11:25.848] [info] Startup 1009
[2026-01-30 15:55:15.915] [info] ------ Main process started ------
[2026-01-30 15:55:16.965] [info] Startup 979
[2026-01-30 23:08:58.384] [info] ------ Main process started ------
[2026-01-30 23:08:59.467] [info] Startup 1018
[2026-01-31 05:07:49.521] [info] ------ Main process started ------
[2026-01-31 05:07:50.527] [info] Startup 950
[2026-01-31 06:14:12.563] [info] ------ Main process started ------
[2026-01-31 06:14:13.733] [info] Startup 1109
[2026-01-31 17:02:13.329] [info] ------ Main process started ------
[2026-01-31 17:02:15.056] [info] Startup 1551
[2026-02-01 19:02:13.629] [info] ------ Main process started ------
[2026-02-01 19:02:14.706] [info] Startup 1019
[2026-02-01 21:37:13.168] [info] ------ Main process started ------
[2026-02-01 21:37:14.503] [info] Startup 1262
[2026-02-02 16:26:01.163] [info] ------ Main process started ------
[2026-02-02 16:26:02.242] [info] Startup 1023
[2026-02-02 18:20:46.637] [info] ------ Main process started ------
[2026-02-02 18:20:47.165] [error] Fatal error app.js { isTrusted: true }
[2026-02-02 19:46:21.498] [info] ------ Main process started ------
[2026-02-02 19:46:22.053] [error] Fatal error app.js { isTrusted: true }
[2026-02-02 20:00:38.048] [info] ------ Main process started ------
[2026-02-02 20:00:38.581] [error] Fatal error app.js { isTrusted: true }
[2026-02-02 21:48:53.422] [info] ------ Main process started ------
[2026-02-02 21:48:53.963] [error] Fatal error app.js { isTrusted: true }
[2026-02-03 00:09:49.485] [info] ------ Main process started ------
[2026-02-03 00:09:50.042] [error] Fatal error app.js { isTrusted: true }
[2026-02-03 21:23:37.462] [info] ------ Main process started ------
[2026-02-03 21:23:37.962] [error] Fatal error app.js { isTrusted: true }
[2026-02-04 17:19:48.224] [info] ------ Main process started ------
[2026-02-04 17:19:48.882] [error] Fatal error app.js { isTrusted: true }
[2026-02-05 17:19:04.676] [info] ------ Main process started ------
[2026-02-05 17:19:05.304] [error] Fatal error app.js { isTrusted: true }
[2026-02-05 22:04:29.706] [info] ------ Main process started ------
[2026-02-05 22:04:30.376] [error] Fatal error app.js { isTrusted: true }
[2026-02-05 23:45:24.453] [info] ------ Main process started ------
[2026-02-05 23:45:25.074] [error] Fatal error app.js { isTrusted: true }
[2026-02-06 16:47:39.718] [info] ------ Main process started ------
[2026-02-06 16:47:40.374] [error] Fatal error app.js { isTrusted: true }
[2026-02-07 17:43:17.733] [info] ------ Main process started ------
[2026-02-07 17:43:18.394] [error] Fatal error app.js { isTrusted: true }
[2026-02-08 20:57:50.338] [info] ------ Main process started ------
[2026-02-08 20:57:50.836] [error] Fatal error app.js { isTrusted: true }
[2026-02-09 00:46:21.337] [info] ------ Main process started ------
[2026-02-09 00:46:21.951] [error] Fatal error app.js { isTrusted: true }
[2026-02-10 18:12:16.586] [info] ------ Main process started ------
[2026-02-10 18:12:17.229] [error] Fatal error app.js { isTrusted: true }
[2026-02-11 08:43:58.105] [info] ------ Main process started ------
[2026-02-11 08:43:59.154] [error] Fatal error app.js { isTrusted: true }
[2026-02-11 18:22:48.892] [info] ------ Main process started ------
[2026-02-11 18:22:49.652] [error] Fatal error app.js { isTrusted: true }
[2026-02-11 19:01:54.748] [info] ------ Main process started ------
[2026-02-11 19:01:55.325] [error] Fatal error app.js { isTrusted: true }
[2026-02-11 19:35:00.189] [info] ------ Main process started ------
[2026-02-11 19:35:00.702] [error] Fatal error app.js { isTrusted: true }
[2026-02-12 20:11:10.561] [info] ------ Main process started ------
[2026-02-12 20:11:11.188] [error] Fatal error app.js { isTrusted: true }
[2026-02-13 05:49:35.718] [info] ------ Main process started ------
[2026-02-13 05:49:36.296] [error] Fatal error app.js { isTrusted: true }
[2026-02-13 13:08:57.950] [info] ------ Main process started ------
[2026-02-13 13:08:58.975] [error] Fatal error app.js { isTrusted: true }
[2026-02-13 15:24:58.940] [info] ------ Main process started ------
[2026-02-13 15:24:59.571] [error] Fatal error app.js { isTrusted: true }
[2026-02-13 17:39:13.100] [info] ------ Main process started ------
[2026-02-13 17:39:13.617] [error] Fatal error app.js { isTrusted: true }
[2026-02-15 20:49:48.740] [info] ------ Main process started ------
[2026-02-15 20:49:49.255] [error] Fatal error app.js { isTrusted: true }
[2026-02-17 16:18:58.290] [info] ------ Main process started ------
[2026-02-17 16:19:00.487] [info] ------ Main process started ------
[2026-02-17 16:19:01.067] [error] Fatal error app.js { isTrusted: true }
[2026-02-17 16:19:50.059] [info] ------ Main process started ------
[2026-02-17 16:19:54.745] [info] ------ Main process started ------
[2026-02-17 16:19:55.256] [error] Fatal error app.js { isTrusted: true }
[2026-03-26 22:44:31.032] [info] Main process started
[2026-03-26 22:44:32.064] [error] FATAL ERROR app.js { isTrusted: true }
[2026-03-26 22:45:03.608] [info] Main process started
[2026-03-26 22:45:06.781] [info] appExit
[2026-03-26 22:45:07.391] [info] Main process started
[2026-03-26 22:45:08.352] [error] FATAL ERROR app.js { isTrusted: true }
[2026-03-26 22:47:12.168] [info] Main process started
[2026-03-26 22:47:13.117] [error] FATAL ERROR app.js { isTrusted: true }
[2026-03-26 22:47:39.618] [info] Main process started
[2026-03-26 22:47:42.656] [info] appExit
[2026-03-26 22:47:43.259] [info] Main process started
[2026-03-26 22:47:44.279] [error] FATAL ERROR app.js { isTrusted: true }
[2026-03-26 22:47:54.494] [info] Main process started
[2026-03-26 22:47:59.003] [info] appExit
[2026-03-26 22:47:59.601] [info] Main process started
[2026-03-26 22:48:00.641] [error] FATAL ERROR app.js { isTrusted: true }
[2026-03-26 22:53:48.176] [info] Main process started
[2026-03-26 22:53:49.198] [error] FATAL ERROR app.js { isTrusted: true }
[2026-03-26 22:54:03.497] [info] Main process started
[2026-03-26 22:54:06.309] [info] appExit
[2026-03-26 22:54:06.889] [info] Main process started
[2026-03-26 22:54:07.854] [error] FATAL ERROR app.js { isTrusted: true }
[2026-03-26 22:54:19.085] [info] Main process started
[2026-03-26 22:54:22.095] [info] appExit
[2026-03-26 22:54:22.675] [info] Main process started
[2026-03-26 22:54:23.609] [error] FATAL ERROR app.js { isTrusted: true }
[2026-03-26 22:58:44.362] [info] Main process started
[2026-03-26 22:59:09.507] [info] appExit
[2026-03-26 22:59:10.091] [info] Main process started
[2026-03-26 22:59:11.058] [error] FATAL ERROR app.js { isTrusted: true }
Are you on Mac or Windows?
For anyone on Windows, we have created a dev version that should provide us with more logs so we can fix the error, please try installing it from here https://drive.google.com/file/d/1gwO1N12C9nKyM8yjyGj6PxQsxfCk8kh7/view?usp=sharing and see if the issue still persists, and if it is, send us the log files.
Thank you for looking into this :slight_smile:
I have uninstalled the previous version and installed the dev version. It is still crashing. Here is the log files:
[2026-03-26 23:14:10.580] [info] Main process started
[2026-03-26 23:14:14.717] [info] appExit
[2026-03-26 23:14:15.305] [info] Main process started
[2026-03-26 23:14:16.306] [error] FATAL ERROR app.js { isTrusted: true }
[2026-03-26 23:23:03.874] [info] Main process started
[2026-03-26 23:23:05.726] [info] appExit
[2026-03-26 23:23:06.317] [info] Main process started
[2026-03-26 23:23:07.319] [error] FATAL ERROR app.js { isTrusted: true }
[2026-03-27 09:31:33.029] [info] Main process started
[2026-03-27 09:31:34.089] [error] FATAL ERROR app.js { isTrusted: true }
[2026-03-27 12:37:42.085] [info] Main process started
[2026-03-27 12:37:43.202] [error] FATAL ERROR app.js { isTrusted: true }
[2026-03-28 00:48:29.452] [info] Main process started
[2026-03-28 00:48:29.702] [info] About to create app window
[2026-03-28 00:48:30.418] [info] Starting app.js
[2026-03-28 00:48:30.419] [info] dbBackupSync
[2026-03-28 00:48:30.419] [info] configureStore
[2026-03-28 00:48:30.475] [info] getStoredState
[2026-03-28 00:48:30.476] [info] rehydrate pre
[2026-03-28 00:48:30.492] [error] TypeError: Cannot convert undefined or null to object
at Object.keys ()
at file:///C:/Program%20Files/FontBase/resources/app.asar/dist/app.js:2:988175
at Array.forEach ()
at Yi (file:///C:/Program%20Files/FontBase/resources/app.asar/dist/app.js:2:988019)
at pathsAll (file:///C:/Program%20Files/FontBase/resources/app.asar/dist/app.js:2:1123683)
at file:///C:/Program%20Files/FontBase/resources/app.asar/dist/app.js:2:741764
at Object.T [as dispatch] (file:///C:/Program%20Files/FontBase/resources/app.asar/dist/app.js:2:740883)
at dispatch (file:///C:/Program%20Files/FontBase/resources/app.asar/dist/app.js:2:743315)
at file:///C:/Program%20Files/FontBase/resources/app.asar/dist/app.js:2:6374385
at Object.dispatch (file:///C:/Program%20Files/FontBase/resources/app.asar/dist/app.js:2:742068)
[2026-03-28 00:48:30.492] [error] FATAL ERROR app.js { isTrusted: true }
[2026-03-28 00:49:04.771] [info] Main process started
[2026-03-28 00:49:06.737] [info] appExit
[2026-03-28 00:49:07.315] [info] Main process started
[2026-03-28 00:49:07.548] [info] About to create app window
[2026-03-28 00:49:08.193] [info] Starting app.js
[2026-03-28 00:49:08.194] [info] dbBackupSync
[2026-03-28 00:49:08.194] [info] configureStore
[2026-03-28 00:49:08.248] [info] getStoredState
[2026-03-28 00:49:08.248] [info] rehydrate pre
[2026-03-28 00:49:08.264] [error] TypeError: Cannot convert undefined or null to object
at Object.keys ()
at Array.forEach ()
[2026-03-28 00:49:08.264] [error] FATAL ERROR app.js { isTrusted: true }
[2026-03-28 00:51:01.797] [info] Main process started
[2026-03-28 00:51:02.025] [info] About to create app window
[2026-03-28 00:51:02.725] [info] Starting app.js
[2026-03-28 00:51:02.725] [info] dbBackupSync
[2026-03-28 00:51:02.726] [info] configureStore
[2026-03-28 00:51:02.776] [info] getStoredState
[2026-03-28 00:51:02.777] [info] rehydrate pre
[2026-03-28 00:51:02.792] [error] TypeError: Cannot convert undefined or null to object
at Object.keys ()
at Array.forEach ()
[2026-03-28 00:51:02.787] [error] FATAL ERROR app.js { isTrusted: true }
[2026-03-28 00:51:14.008] [info] Main process started
Thank you for the logs, they really helped!
We have made some changes now. Could you please try downloading and installing the Google Drive link again and see if the error is still there?
I am pleased to report that I was able to install 2026.2.8 and that it is now running. I will observe it for the next couple of days. By the way, I am a heavy adobe ps, ai, id user.
Thank you so much dominik!
This issue should now be fixed for everyone in FontBase 2026.3.0 release.
