Circling back to this because this issue goes back to 2022 and there is still not a proper resolution in 2024. Having to make the hard choice to start looking at other options - even though we really like FB.
Recap
For Teams, we can’t put our FontBase root folder in Google Drive because then you CAN’T create Watch Folders.
If FontBase is installed locally user CAN use Watch Folders and connect to a Google Shared Drive where the fonts are all located. This also means we can see system fonts as well which is important.
If FontBase is local this means that Collections are also local; which hinders team progress. Auto-Sync Collections feature does not work because, in this scenario, to have Watch Folders work the root folder is installed locally. This breaks Collection sharing.
I understand that there are issues with Google Drive + symlinks that cause these issues but there has to be some kind of work-around or solution that can be implemented.
Proposed Solution
The best solution that I can think of would be to give an options for “Personal” and “Team” Collections.
Personal collections operate as normal, and work out of the FontBase root. Team collections should allow us to to do something like choose the folder location that it reads from; easy enough to choose a Drive Folder that it reads from. This would make sure that Team Members are all able to access the same fonts.
Or alternatively, let users set the save location for both Personal AND Team Collections so EVERYTHING is backed up.
