fontbase no longer loads
win 10
pro
fontbase V2.22.67
Starting the other day, the autolaunch Icon is present in the tray, but the app does not load.
I reinstalled Fontbase last night and had no effect. I have not recently installed anything, nor have I updated Windows.
All I get is a preload screen with a message like ‘replacing all your fonts with Comic Sans’ with a turd icon. not terribly professional btw.
Ctrl_alt_del force close and relaunch has no effect.
I use this for my business, and now have no access to my custom collections.
Hello @iondesig, thank you for your post and welcome to the forum :folded_hands:
A separate thank you for reporting the bug and really sorry for the inconvenience you’re experiencing :pensive_face:
Have you perhaps already had the chance to try resetting FontBase settings to see if that would help? The guide on how to do this can be found here: Reset Settings — FontBase Tutorials
It seems that it’s happening to me too, I’ll try to reset.
on the tray you can see it, it just says Fontbase 2.22.67 Starting
if i Run the program from the start menu an empty window appears with random quotes, like Waiting for the futura!, can’t really make a screenshot of my actual one ast i has to do with boats and countries… :smiley:
Reseting it did the job, no reinstall needed, only terminating the process renaming the folder (so I can have a backup at hand) and reRun fontbase.
