Fonts Being Deactivated On Their Own (Dropbox watched folders)
Ive noticed Fonts will completely deactivate on their own, it’s very random and sometimes it will just straight up deactivate all my fonts and I will have no fonts active. I notice this usually when my computer starts because font base runs on startup. I’m honestly tired of this and thinking of canceling my subscription. The organization is nice but the fonts not staying active is a hassle and im probably going to move to a different app. It’s so basic of a function to get wrong.
  • Sequoia 15.0.1
  • FontBase version 2.20.7
  • What actions caused the issue: I have no idea
  • If possible, attach a screenshot: Would not show anything relevant
Hello @mark21, thank you for your post and welcome to the forum :pray:
Very sorry for the major inconvenience you’re experiencing :pensive:
Are your fonts located on a local hard drive, or a network one (NAS/Dropbox/GDrive etc)?
Thanks @yuriy, I should have noted my fonts are located on dropbox
Thank you for the quick reply @mark21 :pray:
It’s not the first time we’re encountering this app behaviour and as of now we’re still looking for the solution :pensive:
I’ll quote a part of our FAQ below for more background on the subject:
" Why do I experience issues with network drives?
We have received reports of inconsistent behavior when FontBase Root folder is located on a network drive, or when some of the watched folders you have added into FontBase are located on a network drive. By network drive here we mean a drive connected via LAN, a NAS drive, services such as Google Drive, Dropbox etc.
Sometimes it takes a while for your computer to get full access to the network drive, hence the inconsistent behaviour you might see in FontBase. For example, you launch FontBase with a folder on a network drive added as a watched folder and you have FontBase open on computer startup. It’s possiblle that FontBase loads faster that the access to network drive is established, so FontBase tries to check on the watched folder, cannot access it and removes it thinking it was physically deleted from the hard drive.
At this moment we are still looking for a possible solution to overcome the limitations of such network setups. During this time we recommend adding network drive folders as regular, not watched, folders, to make for a more stable experience."
Sorry for not providing a better way to mitigate this right away :pensive:
I’m so glad to hear that you are working on this. I am still struggling with the same issue with my NAS. The only way I am able to keep the network connection alive is to turn off sleep mode on my Mac OS Sonoma (not ideal). I’ve also made sure that the server and mapped drives are permanently launching at startup. The strange thing is that the mapped drives/folders to my server don’t disappear, but the contents are blank until I click on the folder to “wake it up” so to speak.
For example, I have a mapped drive called “Fonts” and that is the watched folder I added to FontBase. When I log in after the computer has been asleep, the folder is still mapped but doesn’t load content until i click on it. Then it seems to “wake up” and reload everything back into FontBase.
The problem with this is that if I have any activated fonts, customization, etc. It all disappears and I basically have to start over again. This is the same experience when I try to use Google Drive, Dropbox or any other service.
Hi Yuriy. I was hoping that there might be some updates on connecting Fontbase with mapped network drives or cloud storage folders. Any advice?
Hello FNF, thank you for your post :folded_hands:
Unfortunately we have made little progress regarding this issue, I’m sorry :pensive_face:
