os: Windows 10 IoT Enterprise LTSC
os version: 21H2
os build: 19044.7417
FontBase version: 2026.5.17
As someone else mentioned here in the Questions section, fonts don’t autoactivate in InDesign 21.4.1.
I report it here in the Bugs section so you can take an appropriate action and resolve the issue.
Thanks in advance.
(obviously I can’t post a screenshot, because in order the issue to be seen it has to be captured in a video)
Hello @Florian, thank you for your post
We’ll definitely investigate this on our end.
Have you had any success contacting Adobe support regarding this matter? In the past, with certain updates InDesign behaved in unexpected ways sometimes, including some plugins not working from what I know.
Hi, @yuriy, did you investigate from your end what is going on?
From Adobe, as expected, they don’t take any responsibility for 3-rd party plugins.
So, I’m counting on you to find and fix the issue.
Hello @Florian, understood, thank you for the quick update
Unfortunately still working on fixing this, as usual, there is some delay between when Adobe makes changes to their apps and releases the updates for developers as to how to build/modify plugins for the new versions
