Freely organize font folders
Hi Everyone,
I didn’t find this topic in any post so I try an attempt : it would be wonderful to freely choose the font folders’ order, with a simple drag and drop. Right now it’s a forced alphabetical order, which is a bit weird because it doesn’t take into account double digit numbers (12 appears before 1).
Would it be complicated to add this feature?
Hello @CyrilDosnon and thank you for your post :pray:
It can be a bit tricky to implement, yes, but probably possible:)
Thank you for putting the topic in the Greenlight category :pray:
Hopefully with enough support from the community it will be added to the list of features to be implemented in future FontBase releases.
Hi CyrilDosnon
Is this really necessary? Alphabetical order ist very common in computer world. If you give the 1 to 9 a 0 before, it’s done so far. :wink:
@ yuriy: I think my former suggestion to change the app auto activation behaviour (auto deactivate on close …) would be more important for those who use it. :wink:
Regards, Matt
Hi Matty,
I’m not the one deciding what’s really necessary or not, I’m just suggesting a feature that I would care for my everyday use :slight_smile:
I have no doubt that plenty of person would find it useless and you probably have plenty of better ideas, but this is just me suggesting an idea here.
ps : thanks for the 0 tip, even if as a designer I like when things are neat :wink:
Hello Matt, thank you for your suggestion:)
