Glyphs missing + question regarding viewing glyphs
Please include the following when reporting a bug:
  • Your operating system- Windows 11
  • Operating system version-
  • FontBase version- 2.23.1
  • What actions caused the issue- dont know
  • If possible, attach a screenshot- yes
Hello to you good people.1 :slight_smile:
I have 2 problems, that are driving me crazy.
Im experiensing something odd. I have a font, that i know contains 303 glyphs. But for some reason, only 208 glyphs are shown in fonbase.
Ive tried this before but didnt have the posibillity to count the actual glyphs in the file- but now i found a page for that: View Font Character Map - CharacterCodes.net
What can cause this? I’ll attatch screenshots of the page anf fontbase app showing the number of glyphs.
After the update, the glyph and character map viewer function is changed, and this change is driving me absolutely insane! I hate it! Before I was able to pres the GLYPS and all the glyphs would show. Easy to do a quick sroll through to see the variants.
Now, its sorted by: basic latin, extended, supplement and what not. This has sloved down my workflow to the point where im reconsidering keeping this fontmanager.
Is there a way to change it back? Change it back to automatically displaying all glyphs, without having to pres the drop-down menus?
Or would i have to reinstal the older program version?
If reinstalling an older version is my only option, it sucks, because that means i will no longer be able to update the app with other features and bug fixes you might release.
Thats all.
Thank you.
Kind regards
Natasja
Hell Natasja, thank you for your post and sorry for the delay :folded_hands:
  1. There are several possible reasons - for the designers could’ve used non-standard character values and FontBase can’t recognise them, or values beyond the standard space could be blank (as can be seen from the last two screenshots), things like paragraphs, tabs etc and the app simply doesn’t include them as the resulting cell would be visually empty anyway.
  2. I’m afraid currently there is no option to revert back to the older Glyphs display tab beyond installing an older FontBase version. It is possible that in the future such an option will be included though, too early to rule it out completely.
