Hi All,
What is the meaning of the grammar check on Preview section? Can I turn off it?
Bela
Hi All,
Bela
Hello Bela, thank you for your post and welcome to the forum ![]()
Could you please explain what do you mean exactly?
I see a red wave line under the text, everywhere
Thank you for your quick reply @robozb ![]()
This is most likely due to your OS spellcheck settings and the preview text language you are using in FontBase.
I don’t think there is a way to turn it off from inside FontBase.
Dear Yuriy,
Thank you so much.
Kind Regards
Bela
