How are Families defined
Hello,
I would like to know how the software decides whether fonts are in a family or not. What kind of (meta)data does it look up?
I am trying to write a script to edit files so that they are grouped by family but I can’t seem to figure out how this is decided.
Thank you!
Hi @postcom, thank you for the post and welcome to the forum:)
It’s based on the postScriptName parameter as far as I know.
Does this help at all?
Hi
Yes, Yuriy is right as far as I know. There are hierarchical layers of style names and in the specific family layer the name has to be exact the same. You can study this e. g. with font converter TransType4 or other font design software. Sometimes also professional font designers does not group the styles.
Regards
Matt
Thanks @yuriy and @Matty! Very helpful. I’ll publish a script here once I’m sure it works properly!
Did you ever finish a working script? I am currently trying to build one myself with ChatGPT, but haven’t gotten it to work perfectly.
