Hi!
Is there a way to uninstall FontBase or reset it to its original settings?
I deleted a repertoire accidentally and I just want FontBase to be as it was when I first installed it.
I’m on a Mac running on macOS Ventura.
Thank you!
Hi!
Thank you!
Hello @ChrisOneTwo, thank you for your post and welcome to the forum ![]()
You can reset all FontBase data by removing (please keep in mind this is irreversible unless you make a copy of this folder first) the following folder: ~/Library/Application Support/FontBase/IndexedDB
Hello @yuriy , for some reason I dont see the font base under the Application Support? So I am unable to reset all FontBase Data.
Hello Christopher, thank you for your post and welcome to the forum ![]()
Are both of these locations empty: ~/Library/Application Support/FontBase and ~/Application Support/FontBase?
is it possible that you have some hidden folders inside this directory, including FontBase’s?
Hello Yuriy,
For some reason I do not see it under the Application Support. I believe I dont have it hidden because there is no need for me to the hide the folder. Is there a way I can uninstall using an uninstaller drive?
Hello again Christopher, thank you for the quick reply ![]()
What do you mean by “uninstaller drive”?
Also, found this article from Apple: Uninstall apps on your Mac - Apple Support
Does it seem to be helpful in your case?
