Impossible to minimize window after previous update?
  • Your operating system- Windows 11
  • Operating system version-25H2 (?)
  • FontBase version- 2026.3.0
  • What actions caused the issue-Updating the program. not to this, but the previous version-before it was possible to minimize.
  • If possible, attach a screenshot- Yes
Since updating to the previous version, it is impossible to minimize the window. I can narrow the horizontal size a bit, but not as much as i used to.
Before I was able to minimize it to whatever size i wanted- and i used to use it vey small an slim.
However now ithe size in the picture is the smallest i can get it both horizontally and vertically… This is a problem for me, when navigating between the different windows/programs.
Do you have a solution for this?
Please?
Thank You.
EDIT: I am unable to attatch picture as of now. Do not know why, but that is the message it gives me… Will try later. But for referance, the window is taking up over half of my screen and almost from full top to full buttomn.
What is your screen resolution?
My Screen resolution has not changed- it is and has been the recommended setting of 1920x1080.
Does that affect the ability to minimize or maximize the window?
I have just updated to the 2026.4.1 version and the problemhas not been resolved. I didnt think it wouls, as the udpade info that was released with this one, didnt mention anything about bug fixin. Nut wanted to let you know anyway.
PS: I am still no able to attatch a photo. it keeps giving me this message:
Sorry, there was an error uploading Screenshot 2026-04-17 175332.png. Please try again
