I just installed the latest FontBase as I paid a yearly subscription. The plugins for InDesign 2024, Photoshop 2024 seem to be installed but none for Illustrator 2024. Is there a bug or have FontBase not developed one?
Hello @Modesty, thank you for your post and welcome to the forum ![]()
Did you have a chance to check out the Settings page, namely the Plugins section, and see what is the situation with the Illustrator plugin there?
FontBase does have an IL 2024 among others, yes:)
Same happened to me and a Colleague. I downloaded and installed all versions from 2.19.1 individually (even going back and forth between some) and at some point the illustrator plugin appeared and now works. I don’t know why it wouldn’t appear “normally” but this seems to be a problem for a lot of people (the file not appearing) - you could solve this easily by making the individual plugin files available for download.
Hello @la_wurm, thank you for your post and welcome to the forum ![]()
And a separate thank you for your suggestion ![]()
Sorry about the inconveniences along the way, but glad to hear it worked out in the end.
Btw, big fan! Keep up the great work! Cheers
