I had Fontbase on PC and it worked fine, but I have tried it on mac and it’s missing most of my fonts.
I have a folder which I have set as my Root Folder. It has over 5000 files and folders in, but when i search for one of them it can’t find it, though I can find the file in the stated folder.
I don’t know what I have done, but can it be fixed so I can used my fonts?
Hello @MarkWaudby, thank you for the post and welcome to the forum
That’s indeed odd behaviour, given the font folder is identical.
Would it be possible to try to remove the folder from FontBase, then re-add it?
If that’s not going to do the trick for some strange reason, then could you please try to reset FontBase settings using this guide Reset Settings — FontBase Tutorials and restart it again and add the font folder you’ve mentioned?
Hello @MarkWaudby, thank you for the quick reply
Hmmm, that’s odd.
Would it be possible to uninstall the application and re-install it? These folders should be created when FontBase is installed.
Tried re-installing but it has made no difference and the folders haven’t been created.
Stupid question but I am installing it properly? I quite everything. Dragged the FontBase icon for applications into the trash. Emptied the trash. Restart the mac. Downloaded the installer. Ran the installer. Dragged the icon into the applications folder. Ran the program.
Hello @MarkWaudby, sorry for the delay
This situation is very odd indeed.
Would it be possible to run a search on your computer’s folders to find all folders titled “FontBase” to see where this folder is being created? The fact that FontBase settings are saved after uninstallation means it’s there somewhere, just in a different place for some reason I can’t quite understand yet.
Thank you for such a quick reply @MarkWaudby
Hmm, none of them look like the settings folder we’re looking for
If possible, could you please also try running a search on the following file: “file__0.indexeddb.leveldb”?
Just to let you know I have found a way of completely uninstalling the software deleting every occurrence of FontBase, and then re-installing. I now have all my fonts. Phew!
