New top menu bar icon sizing and rendering
Hello. The new logo that appears in the top menu bar of MacOS is distracting because it is taller than typical menu bar icons and the shadow does not render because menu bar icons must be opaque. See attached screenshot.
Screenshot 2025-08-13 at 1.04.20 PM
I’m on MacOS 15.6.
Hello @mediachunk, thank you for your post and welcome to the forum :folded_hands:
The size is indeed taller, will fix this soon, thank you for bringing this up here.
As for the shadow - that is the intended display as I was told.
Hi @yuriy, thanks for quick reply! I’m glad to hear that a fix is on the way for the height.
