Restarting FontBase should do the trick. If it doesn’t, would it be possible for you to download the installer from FontBase — Download for Mac and running it?
Also, a new update was just released today. Did it change anything update-wise or is your FontBase still at 2.17.16?
It worked! Thanks. Plugins are running as they should (M1).
Brilliant!
Thank you for the update, apologies it took so long to fix ![]()
