Providers not showing in their section
Since the most recent update, the fonts that I had in different provider folders suddenly don’t show on my FontBase anymore. When I click on the Root folder > Providers, then I can see all my fonts in their respective Providers just as I set them before.
I work on Windows 11 and FontBase version 2.24.9
Hello Phobialia, thank you for your post and welcome to the forum :folded_hands:
This behaviour is odd indeed. Also, based on the screenshot, you have extra fonts in your Google provider - are you storing any extra fonts there?
By fonts that you had in different provider folders do you mean any fonts you’ve copied there yourself? The Providers folder is designed to be managed through FontBase directly, not via a file manager.
I think the same thing is happening to me, im on a mac but in the last month or so all my fonts have dissapeared from the fontbase app but i can still see them in the finder folders:( Tried reinstalling the app and everything but nothing works:( I am on MacOS Tahoe 26.2 and have Fontbase v2.25.10
Hello Pernille, thank you for your post and welcome back to the forum :folded_hands:
Have you perhaps already had the chance to check if your root folder path in the Settings page is pointing to the same folder where you stored your FontBase fonts previously?
Hi! Yes its the right path so i dont understand what has happened:(
Hello @pernillere, thank you for your reply :folded_hands:
Just noticed you’ve mentioned app version 2026.2.10 - where did you download it from if I may ask?
This seems a bit odd, since the latest version on our website is 2026.2.5.
Downloaded it from your website, the version is now 2026.3.0 and still not working:( Even redownloaded and installed but that didnt fix it either:/
You could try selecting a different folder as FontBase root, and then picking the old folder again after that. Just remember to make a backup copy of your FontBase root.
If that does not work, you could also try to reset the settings as described here https://fontba.se/learn/reset-settings
