Change background, change font display color, exit.
Is this normal behavior? This level of personalization needs to be set every time the app is cycled because it is not saving them. Kills the vibe of using it as a feature.
Hello @hyp0xia, thank you for your post and welcome to the forum
This is indeed normal behaviour.
I’ve moved the topic to the Greenlight category, and, with enough attention from the community, the respective change will most likely be added to one of the future updated to FontBase
