Startup Alert (InDesign)
  • OSX 26.4
  • InDesign 2026 (21.2)
  • Fontbase 2026.3.0
  • Dialog after latest update…
Startup Alert
Adobe InDesign cannot load the FontBase-Mac-InDesign-2026.InDesignPlugin plug-in. The FontBase-Mac-InDesign-2026.InDesignPlugin plug-in requires the 21.3 version of InDesign. Please contact the vendor to get a compatible version of FontBase-Mac-
InDesign-2026.InDesignPlugin.
Show this alert again?
No / Yes
Maybe there is coming fix for that?
You will need to remove the FontBase plugin in settings and then install it again.
If you upgrade your InDesign, the new plug-in will work.
