Hi,
I was a $3 subscriber but decided to take the plunge and go Lifetime. But it looks like both subscriptions are active at the same time. Will the $3 one end by it’s self at the end of the month or do I need to do it manually? I was nervous about canceling it after seeing the message.
Hello @Kdec101, thank you for the post ![]()
Yes, you’re on the right path. The way to go is to cancel the monthly subscription, it will not affect your lifetime access.
Thank you for your support ![]()
