TAGS file location
Hi!
According to the information you provided, all application data — including tags and collections — can be duplicated by copying the full folder located at
~/Library/Application Support/FontBase .
My question is whether you could tell me which specific file or subfolder within that directory contains only the personal tags .
I had to uninstall the application because it was crashing, and when I restore the full folder, the issue occurs again. For this reason, I need to copy and restore only the file or folder that contains the TAGS, avoiding the rest of the data that might be causing the problem.
Thanks.
Hello Hernan, thank you for your post and welcome to the forum :folded_hands:
Such a separate file/subfolder does not exist at the moment I’m afraid :pensive_face:
