Watched folder tree in left panel doesn't show, but fonts are adding
  • Windows 11
  • Windows Version 22H2
  • FontBase version: 2.20.7
  • I Added a watched folder, and all the fonts get added correctly, however there is no file/folder tree in the left side panel under “Folders”
    I was just testing this watched folder option and I need to make changes, but there is no folder to “remove” or modify. I can change the name of the actual watched folder, and it does remove all the fonts in FontBase so I can work around this for now.
  • If possible, attach a screenshot:
Thanks!!
Hello Mike, thank you for your post, sorry for the delay and welcome to the forum :pray:
If you open your Root folder, do you see the folder you’ve added as a watched one there?
I am having the same issue as described. The folders do show up in my root folder on the hard drive but not in FontBase.
Hello @theoryprint, thank you for your post and welcome to the forum :pray:
Are the root folder and the watched folders you’re adding located on local hard drives?
The root folder is. The watched folder is not on a network server. I had it setup before but deleted it and now I can’t get it back.
Thank you for your reply :pray:
Do you have the same issue with other folders, e.g. located on the same local hard drive?
