My activated fonts in FontBase aren’t showing up in Figma. They show up in every other app (e.g. all adobe apps and office apps), though. And if I install them directly, they show up fine. When I activate, I can see them show up in my main font directory that Figma uses, so no issue there either.
I’m using the most recent desktop app on Windows 11.
I’ve tried:
Changing my root folder to “C:/FontBase” from FontBase settings
Uninstalling and reinstalling both Figma and FontBase
Found a solution. I had to update Windows to an advanced build that’s outside of the normal updates. So I’m sure it’ll be sorted with the next official update of Windows 11
It stopped working for me as well. No matter how many times I activate/deactivate the fonts, they don’t show up on Figma. They are showing up fine on other apps (Adobe Suite, Word, etc.).
Hello @serhiishakh and @humanespace, thank you guys for your posts and welcome to the forum
Do you remember when this started happening?
What were the last changes/actions on your machines after which activated fonts stopped appearing in Figma?
Have you perhaps already had the chance to try to possible solution mentioned above?
I’m afraid Figma is a bit different from other desktop apps in terms of how it accesses fonts, hence the current issue you’re seeing is most likely not due to changes in FontBase, but rather inside Figma itself, or possibly inside the Windows OS
I have tried updating my Windows to Insider Preview Build but it doesn’t seem to help.
Figma updates are pretty frequent, it is probable that it’s updated last week.
Thank you for all the additional info
This is indeed pretty odd
Would it be possible to try to revert Figma to it’s slightly older version (any time before the issue started) and see if that would make a difference? Could help in understanding what the problem is and what can be done about it.
Thank you for your reply and the additional info
I really hope fixes this soon, sadly I don’t think there is anything we can do on our end to remedy the changes inside Figma
EDIT 01/08/2024 *I really hope Figma fixes this soon…
Thank you
And thank you for the original, and welcome to the forum
Have you perhaps already had the chance to try reinstalling FontBase after the OS update?
Based on the discussion above it’s also possible something changed inside Figma recently Fonts Activated in FontBase Don't Appear in Figma - #15 by serhiishakh
and if that’s the cause of the issues you’re having, I’m afraid there is little we can do on our end to remedy that
But it’s possible a re-install and resetting the settings (Reset Settings — FontBase Tutorials) can return things to normal
