Hi yuriy
If you don’t have the latest InDesign, InDesign alerts, that the Plugin requires at least version 21.3x. Is there no other possibility to work with an older version?
Win 11, Fontbase 2026.3.0
Regards, Matt
Hello Matthias, thank you for your post ![]()
Would you happen to remember which latest FontBase version contained the plugin that worked with your InDesign version?
Hi yuruy
I’m afraid not because I just startet to use auto activation again with version 2026. I’m wondering why this happens, because in InDesign there shouldn’t be a difference causing this version issue.
Regards, Matt
Thank you for the quick reply ![]()
DM’ed you an older version with some instructions.
Hopefully it will work.
Many thanks, yuriy, it works again.
