InDesign Plugin für older versions of ID 2026
Hi Yuriy
Could you please give me a link for an older version of the plugin again. I lost it because of updating Fontbase. I missed to backup it in an other place than the Fontbase plugins folder in programs (content of folder was deleted during update).
[InDesign Plugin 2026]
Thanks, Matt
Hello Matt, thank you for your post :folded_hands:
DMed you the link, please let me know if the linked plugin works as expected.
Hi Yuriy
No doesn’t work unfortunately. This seems to be the new version (the same as I have installed).
Regards, Matt
Thank you for the quick reply :folded_hands:
Apologies, sent another one, this one should work, still please let me know how it goes.
Thank you for always reply quickly. But no, doesn’t work. It looks like it is allways the same version (the newest one) when I look for file information and date. If I replace it directly InDesign dosn’t warn any more but it doesn’t work. Replace it with new Installation InDesign warns as before.
PS: Maybe it didn’t work before update and I didn’t notice this because InDesign didn’t warn when manually copied. But plugin is always the same version I think (march 30th 2026).
Thank you for replying so quickly and sorry this is taking so long :folded_hands:
Found an even older plugin version, sent in DMs, hopefully it will work this time.
Hi yuriy
Thanks very much, autoactivation now works again with this version. So we are done with the issue.
Though InDesign does not work stable with it in addition to the live-activation behaviour. Maybe system restart helps or somthing other in InDesign makes problems.
Regards
Matt
PS: after system restart InDesign seems to work again with autoactivation. Thanks again
