Hello Yuriy,
thanks for your help, it works. The hint with the root folder was essential. Your post should be pinned as solution.
Best
Mehmet
Hello Yuriy,
Best
Mehmet
Thank you for the update Mehmet, glad it worked out ![]()
Would you happen to remember approximately how many fonts you had in your Root Folder before the crashes started? The cause was most likely somewhere in the Root Folder contents.
Did you have any other files besides font files in there?
Hello Yuriy,
the root folder contained approximately 350 fonts. Some of them were in separate folders. Some of the folders contained
-PDFs License Information
-RTFs License Information
-zip (added wrong font folder including the zip files)
Best regards
Mehmet
Thank you Mehmet for the additional info ![]()
Just tested this and PDF, RTF and ZIP files didn’t cause any problems. For now it looks like something odd was going with one or more of the 350 fonts ![]()
Would you be up for an additional investigation - adding back those 350 fonts in batches (e.g. 50 at a time) and seeing if the issue would re-appear? It would really help in narrowing down the cause.
